Oh, that's really interesting. If they are cycled down to 3kWh usable capacity, should I expect them to have as many cycles as a "new" 3kWh LiFePO4 battery?
I wouldn't make that assumption. Battery life is typically defined as the point where the battery has 80% of the rated remaining charge capacity.
3kWh for a 5kWh rated battery is only 60% of original capacity. If batteries were still reliable when this heavily used, then why would industry standard be to replace batteries that have dropped to 80%? Its not like people like throwing away money.
Using these could be a real crap shoot. They might be good for a long while yet, or they could die tomorrow.
-Edit-
I see the owner of the company jumped in and explained these are built using NOS cells. That can be good, depends on how the batteries were stored. What SOC and temperature where they stored at? BB probably knows, question is where they all treated the same or are they kinda random. Some stored at 100% SOC outside in Phoenix? Some stored at 30% SOC in Minnesota. Storage conditions makes a huge difference (give me the Minnesota cells over the Phoenix cells).
If BB is sorting and binning cells by capacity and IR, then these could be an excellent value. If they are just grabbed at random from a crate, then it could be random luck what quality of pack you get.
Also are these batteries packs built using individual cell fuses? Telsa cells have an individual fusible link for each cell so if any single cell goes bad you just lose a bit of capacity. Without this, a dead cell could result in a dead battery pack or worse a fire.
Here is a D.I.Y. friendly example of cell fusible links.
Each foot equals 15 cell connections long by 2, 3, 4, 5, or 6 wide. For example 2p wide would be 30 cell connections per foot (2 wide x 15 long) and 6p would be 90 cell connections per foot (6 wide x 15 long) Introducing custom cell level fused nickel design that can be spot welded with ease...
batteryhookup.com
-Double edit-
Now I am really confused, the BB owner claims these are from Tesla battery packs, but then I see claims they are LiFePO4 cells. To my understanding Tesla uses Lion cells, not LiFePO4. What voltage are these cells? 3.2V or 3.65V?
