I would suggest one or two smaller 2200-2500w inverter generators. One for charging the batteries, two if you need an extended run on aircon. They are much easier to handle, and will sip fuel when not running aircon. set the imbound power limit if your inverter has that capabilityI already have a 5000 watt generator. It's a pain to drag out, hookup, needs a lot of gasoline and is noisy. I only want to use that if I don't have any solar or battery power.
Your Metal Clad Cable/Conduit seems awfully close to exposed lugs. Maybe wrap some protection around it?Got the wife on board (extra energy security), so I pulled the trigger and my second 6 pack of batteries will arrive Friday.
What is the consensus on hooking up rack #2 ? Can I just connect the 4/0 cables on top of my existing 4/0 cables ? View attachment 140621
I just sprung for bigger bus bars. Never ending money suck. But I love it.Got the wife on board (extra energy security), so I pulled the trigger and my second 6 pack of batteries will arrive Friday.
Amen to that.I just sprung for bigger bus bars. Never ending money suck. But I love it.
Yes, I agree. The MC cable was installed first then the battery cables. Now that it's all working, I need to go back and tidy up - and move the MC away from the DC stuff.I would connect a battery cable to each end of the bus and double up inverter cables as required.
And please, move that MC cable somewhere else.
I could do okay with 30kwh most days until I throw the 3 ac units on it. But even without the AC, if I go 3 days without sun it's going to go into bypass. I reckon I could move to a smaller house but no, I don't see that happening. I'm just getting done with the solar here. No way I'm starting over.Dang you guys really do like to waste money...I do great with 30kwh of storage. If you're going over that, you need to learn to use less electricity. If I had natural gas heating I would only need 15kwh. I charge my EV fine too since i have a lot of surplus during the day.
I just bought another rack as well, and spent the afternoon today reconfiguring my bus bar layout, going from a set of 300A bus bars to a set of 600A 12-stud bus bars from Signature Solar.Got the wife on board (extra energy security), so I pulled the trigger and my second 6 pack of batteries will arrive Friday.
Might want to take a look at the Victron Power In’s for your buss system. It’s a nice setup for around $150. Has both the positive and negative buss all in one neat box and they can be expanded as necessary. 1000 A rated.I just bought another rack as well, and spent the afternoon today reconfiguring my bus bar layout, going from a set of 300A bus bars to a set of 600A 12-stud bus bars from Signature Solar.
There is something comforting about turning on a switch and having the lights go on even if the power is out.I could definitely get by with much less.
But, why would I want to. If I don't have to.
I chose this path for the freedom it affords me.
Since throwing the switch and having my house off grid, I've increased the Kwh used per day. Batteries get fully charged each day so I'm using up the rest of the Kwh my panels are generating. Went from less than 20Kwh per day to over 50Kwh per day for this time of year. I get payback much quicker this way.Dang you guys really do like to waste money...I do great with 30kwh of storage. If you're going over that, you need to learn to use less electricity. If I had natural gas heating I would only need 15kwh. I charge my EV fine too since i have a lot of surplus during the day.
Same here. I "waste" energy as much as I can on sunny days.. Boiling water to combat dry air and using a 'portable' sauna are two of my favorite ways. Soon enough pumping water for the garden and running AC will take over.Since throwing the switch and having my house off grid, I've increased the Kwh used per day. Batteries get fully charged each day so I'm using up the rest of the Kwh my panels are generating. Went from less than 20Kwh per day to over 50Kwh per day for this time of year. I get payback much quicker this way.
That’s what you get for opening your big mouth and bragging. Big man is watching.My neighbor was by yesterday, he had to order more LP gas for his house. I told him I haven't used any LP during the day since throwing the switch unless it is poor sun for the day.
This morning was foggy with snow on the way tonight into tomorrow so have no idea what production will be. I didn't run any electric heat today.
