Blowing fuse while charging battery for small solar shed light
pothos
Canada
I put togethe a shed light as a first project (specs below). However my 7.5A fuse keeps blowing while charging and not using the light. Is it safe to incrase the fuse size to 10A or is there somewhere else I went wrong? The panel isn't in full sun but I figured that it would be sufficient to only use the shed light for several minutes per week. I find that after the fuse blows, the display on the charge controller shows EO1 which means the battery is over dischaged.
12.8V 6Ah LiFePO4 battery
Renogy 10W 12V solar panel
Renogy 10A PWM Charge Controller
5V USB light strip connected to the 5V 2A usb output of the charge controller
18 AWG cable with a 7.5A mini inline fuse close to the battery on the positive/red wire to the battery.
18 gauge wire will not hold 10 amps especially if it's over any distance
Is this the fuse between the solar panel and the charger or between the charger and the battery?
Also you really shouldn't use a PWM charge controller with a lithium-iron phosphate battery
Hi Eric, the fuse is between the solar charge controller and the battery on the positive/red wire.
Why should I avoid a PWM charge controller with a LiFePO4 battery? Are there any small MPPT charge controllers that you would recommend for this battery?
Thanks for the help.
You should consider increasing the wire size to something a little more manageable... 10 or 12 gauge would be just about right
Generally speaking PWM charge controllers simply Don't have enough programmable options to be set up properly for lithium iron phosphate... Not to say that they can't be used, but that they just simply are not ideal...
Additionally the vast majority of them are based on a unit that can be purchased on Amazon for about $12... Yes even the one that you've listed
It's also important to realize that MPPT will charge your batteries significantly more efficiently
Keep in mind, PWM is going to take whatever amperage the solar panel is providing and pass that on to the battery... Well simultaneously lowering the voltage to the appropriate charge voltage
So with PWM it is extremely important that you are as close to charge voltage as possible
For instance if you were using a solar panel to put out 16 volts and 6.25 amps(100 watts), then it might come down to say 14.4 volts and 6.25 amps... Which is about 90 Watts.. so not a huge deal
But let's instead say that it is a 28 volt panel at 3.58 amps... Still 100 W panel
But that turns into 14.4 volts at 3.58 amps or about 51 Watts... So 51% of the power actually passes through... And it's even lower than that by the time you account for cable losses and other such things
For the most part you would expect any MPPT charge controller to be somewhere in the mid to upper 90s on conversion rate... To be honest I have units where I'm running 10 times the voltage of the battery and still seeing around 98% conversion rate.. But more importantly than that I'm able to program the batteries to charge exactly as I want them
As for unit that is affordable that is MPPT
PowMr 12V 24V AUTO 20Amp solar charge controller, MPPT charge controller Intelligent Regulator w/LCD Display for AGM, Gel, Flooded and Lithium Battery Charging https://a.co/d/6W8lznT
You have a very low power system. A 10 watt panel will be current limited well below 1 amp.
The fuse you have will protect any circuit collected to the controller load outputs and USB outputs. Something in your circuit is making a short across the positive and negative wires. Can you provide a rough diagram of the system? What length of led strip are you using?
For a simple basic experimental system there is nothing ' bad' about using a PWM controller, its just not ideal. A 10 watt panel wont deliver much power , especially if its shaded. Its possible the battery wont be charged enough to power the load for long enough to be useful. 18 awg is good for 15 amps so fusing at 7.5 is OK. With the very small charge current, the panel maximum is around 0.5 amps, and the USB circuit will be a few amps, so everything is within the capacity of 18 awg.
The very low cost PWM devices are not well made, 1 so there could be a fault In the unit.
To be honest your system doesn't justify a expensive MPPT controller. However if you decide to build a larger system then a MPPT is justified. The best value for a reliable MPPT is the victron smart range.
The best mppt is the victron smartsolar 75/10 .
That unit you can adjust the max amp to the battery.
You can set it on 1-10a
And its fully program how you like to program
So you can set your lifepo4 on 6a charge profile what is the max of your battery
The problem its cost a lot .
But for the battery its really the best to have .
For the rest .
That renogy cost in my country about 50 euro.
The victron 75/10 cost 65 euro.
For the rest go for a 25watt solar panel.
That do about 1.7a charging on a mppt.
Personal i go for a 50watt panel that do about 2.7a
I know that i will thake that Victron any time.
As pointed out by mikefitz, with that solar panel the solar charge controller shouldn't have been able to generate enough amps to blow a 7.5 amp fuse. But if the wires are undersized and too long it might happen.
Use this wire size calculator to check to see what size wire should be used: https://https//baymarinesupply.com/calculator
The usual rule for fuse sizing is 1.25 times the expected amps. Worst case scenario is that your solar charge controller produces 10 amps, so a fuse rated for 12.5 amps is about right.
Still, something is out of what that you blew that fuse in the first place.
Lets talk about the wire gauge.... I see misleading info posted here...
Basically, you need to know 4 main things when determining what gauge of wire works for your circuit:
+ Maximum amperage of circuit
+ Maximum allowable voltage drop
+ Maximum length of wire in the circuit
+ what type of wire you're using: solid copper > nickel plated copper wire > copper clad aluminum > solid aluminum
hint: > = greater than / better than
Also there's no way to say for certain that a given wire gauge is the wrong (or right) gauge if you don't know at least those 4 basics: i.e. a 6 inch long single conductor (solid or stranded) solid copper 18ga 450C insulator wire (commonly referred to as MG or Mica Glass insulator) at 100F ambient temp can support 31 amps DC continuous power handling, but at 10 feet that drops to about 9A DC continuous power handling. This is because: the larger the wire diameter, the lower the resistance. Lower resistance = lower the voltage and amperage capacity drop over distance.
For the rest .
Ridiculously oversized (and overpriced) for a 12v 6Ah battery being charged from a 10w 12v panel!!!
(even the Renogy charge controller is massively oversized and could handle up to 120w of panels at 12v)
The battery size is very small as well- but the Renogy has a very low (less than 10mA) self consumption- so it uses about 0.25Wh a day just sitting there, the battery has a 'actual' capacity of 77Wh of storage (but the panel would be lucky to get to 40Wh a day in most places so if you did flatten the battery, it might take a couple of days to recharge depending on your location), the Renogy controller 'can' output up to 10A, but with only 10w available, it would never get above about 1A from the panel- so thats not the issue, and same with the LED strip- its a 5vdc 2a limit (10w) on the USB outputs of the Renogy so a 10w led strip, so at the 12v nominal, it would never draw more than 1A from the battery....
So it makes no sense that a 7.5A fuse blows...
(short of an actual possible short circuit somewhere....)
Is there a smaller solar charge controller that you'd recommend? Ideally MPPT since it gets quite a bit of shade in the summer but I only really use the light for a minute or two most days.
I have switched to 12AWG copper clad aluminum wire between the battery and the charge controller, and upgraded the fuse from 7.5A to 10A. Fingers crossed the battery recovers from its over-discharged state.
With a 10w panel you'd spend more on an MPPT than your entire system combined. At best you gain a watt. Until you're looking at 200-300w of panel a new SCC isn't going to do you any good.
You've still got a short in there somewhere, likely the USB port. Disconnect everything but the panel, SCC, and battery. If it starts taking a charge you can throw your 7.5a fuse back in and start reattaching your loads. When the fuse pops again, that's your problem child.
Expect it to take 8+ hours of good sun to get that battery filled back up.
I was just disagreeing with the Victron suggestion- that is a quite 'large' capacity controller (for this application at least) and at their price range, would be one of the most expensive parts of the entire system lol (in fact, it would be the most $$$ item...)- even the Renogy is a lot larger than is needed
Remembering that your battery is extremely small, and can't handle a panel wattage of more than about 75w anyway (that MAX charge current for that battery is 6A max- and that would be stressing that little battery)
Not a fan of the 'elcheapo' ebay/ali units, but this is the kind of stuff they are prime for- a tiny, cheap and rarely used setup- you wouldn't put in a $10k 48v 6kw system to run a 10w shed light- and the equipment prices should reflect the usage needs...
Okay, so I got it to stop blowing the fuse but I still have issues.
Here's what I did:
Bear in mind that this is a recreational/educational setup to get shed lighting and is mostly a learning experience. But it is still cheaper than hiring an electrician to hook my shed up to the grid.
At this point, the battery still refuses to charge - even when I have the USB light unplugged and I do not touch it for 2 weeks. I had a spare 10W panel, so I tried hooking that up in parallel to total 20W. It still won't charge the 12W 6Ah LiFePO4 battery enough to turn on the light for more than a couple seconds after another 1 week of charging.
Could the solar charge controller be self-discharging too much? I only intend to use the light for several minutes per week.
Any links to the smallest feasible solar charge controller are welcome... Pretty flustered at this point but still eager to get it working.
10W solar panel is not exactly a whole lot of power for charging or even maintaining a battery. Have you tested the voltage output and seen it is at least outputting 17vDC while in sunlight? It needs to be at about that to charge your lithium battery.
I would suggest getting your battery properly charged up to ensure you have not damaged it by being over discharged for an excessive period of time. I do not know it your battery has a BMS that possibly disconnects at low voltage. If it does that would explain why it will not charge from your solar. Voltage readings should be made of your battery.
If you do not have a Digital multimeter you really need to get one.
Optimal mppt and 20watt solar it will charge optimal about 1.4a
But really life it just gone do 0.8a
For the rest i think that you have to set the panels in series .
So your volt go up so your mppt can start
It can than mppt will not start to the low 18v vs 13.2 volt battery
Means that is just hit 5v difrence to start a mppt .
What with not good optimaal day it never gone hit it
A diagram and picture of the set up would be useful, as would the voltages at points in the system. You need to identify the cause of the issue before throwing new parts at the problem.
Measure the panel output disconnected from the controller. Measure the battery voltage. Will the battery charge with a AC charger and then power loads?
