Bluetooth Shunt or Bluetooth BMS or both?
Bobbiejamie
Off grid system newbie
Hi everyone, just joined the forum and this is my first post. Thanks in advance for any advice.
Haven’t built a battery before but I’m leaning towards the 3.2V DIY option for my battery bank (24V, 280 Ah 8S). I’m looking at the Victron Energy shunt w Bluetooth connection, so I can monitor the batteries, but I see that a lot of BMS’s have Bluetooth as well. Do I need the shunt if the BMS has this feature? Does it give me anything more than what I’d have w the BMS in terms of monitoring from my phone?
Thanks!
I think the BMS’s are only working back they capacity from voltage , rather than a shunt which looks at then energy leaving and being pushed into the battery.
I think of it as BMS gives an indication , a shunt will provide a true indication of capacity
The Victron SmartShunt will give you battery level coulomb counting and voltage and includes a nice Bluetooth App.
Your BMS will give you cell level voltage and if/when balancing is occurring if that is part of it’s function.
Two different things. Either, both or neither can be Bluetooth.
Reactions: JMc
