sailingharry
Not sure if this is the right subforum, but it seems right.
I have a simple (ha!) system, consisting of 4 BlueSolar, a 3kVA Multiplus, a SmartDongle, and a Battery Protect. My BMS (ElectroDacus) is not Victron-friendly (at least out of the box -- apparently it's not terribly hard to make it talk), and I track my SOC using a Link2000 (ancient but fully functional and in a nice easy to see place). All of the Victron stuff talks to VictronConnect on my cell phone. I have no interest in the expense and complexity of a Cerbo (and all those wires!), and even the Venus solution isn't really attractive, as it still requires wiring all those pieces together.
Here's my thought. All the Victron stuff comes into my cell. It even is "live" since Victron added that neat feature where the list of equipment inlcudes 3-4 useful data fields on the home screen. I should think that a phone app could approximate a Cerbo. It would add all the solar together, in a single number. It could add any charge from the MultiPlus. It could show the status of the BP (although woudn't show any charge from "dumb" sources on the BP, such as my Watt&Sea -- a towed water generator -- and my Victron Centaur). It would show the status of inverting (on/off, controlled by a physical switch) and current from the battery. It can't show any battery info (SOC, net current) except volts and would have no idea about the alternators. It basically would add up and present all the numbers shown on the VictronConnect home screen, and require ZERO installation or additional components.
Does this exist? Is this something a smarter person than I could do? Is it on the way?
