My newly purchased Bluetti AC200P wouldn't charge with a 2nd AC charging brick. I got in touch with CS, discussed the problem back & forth with emails, and they sent me a new Bluetti AC200P replacement. The replacement Bluetti won't charge thru the solar port using a 2nd AC charging brick either. The solar port will charge using the 12V cigarette plug and I get about 93watts or so there while also charging with one AC charging brick in the other charging input at the same time. But when I connect 2 AC charging bricks the 2nd AC charging brick will not charge. The menu is selected to PV. I'm hooking up both bricks exactly like it shows on Bluetti's website. I've even plugged both bricks into two different 120V outlets that are on different circuits. I find it hard to believe that 2 different AC200P units have the same problem. Their website and instruction manual offers no help or instructions to troubleshoot.
I have ran multiple tests to make sure both bricks are working, used a multi-meter on all cabling and everything seems to be fine.
What am I missing?
Is there a certain procedure I should be following or other menu options I should be using to be able to charge with 2 bricks? Any ideas will be very helpful. Very frustrating.
What am I missing?
