Huskydriver
- Jan 14, 2021
- 7
I'm thinking about getting a Bluetti AC300. I'm just curious on the solar input. It says it can take up to 2400w of solar, but it's two separate inputs. I was a little confused by this. I have a bunch of 320w panels rated at 40v and 9.8a each. I currently have an AC200 max that i have using three panels in series, but if I doubled it and ran it in parallel it would exceed the AC300 input amps. My question is can I run two seperate series strings to the AC300? The Bluetti says its max input is 2400w 150v 12a, but it also says it has two inputs rated at 1200 150v 12a, so are these two seperate inputs? Running two in parallell to the unit would exceed the amps, but if they are separate inputs then maybe it's possible running each in series which i already do with my AC200 max.
