BMS app confusing me
moonlitsouls
Hey check this out , my battery is running a 100w right now but this app is saying it’s discharging almost 8amps
I checked and a 100w load should be pulling .83 amps
why does this app show 8amps then?
The BMS is measuring BATTERY current. Power = Volts * Amps.
7.98A * 13.24V = 106W
12V Battery current is approximately 10X the current needed for 120VAC. You computed the current for 120VAC.
Power = Current x Volts So, 13.24 times 7.98 = 105.6552 .... rounded up = 106
edit.... Ok, I was too slow that time.
Ahhh yes mr snoobler , and this is why I come to the experts
Would you guys mind taking a look at this
