undercrust
- Nov 7, 2022
- 18
Looking for recommendations here. I'm using the Overkill BMS app with my JBD 120A BMS (JBD-SP04S034-L4S-120A), and after tweaking the settings it's been working fantastic.
However, I can see more clearly now that tracking how much battery I've used while I'm off camping is going to be a bit more difficult, since the app does not provide feedback on cumulative usage as "seen" by the BMS.
Q1 - Is there an equally capable app that will provide a view on cumulative usage as seen by the BMS?
I know already that this will be much less accurate than using a proper shunt, but honestly I've pretty massively oversized my battery, so this would be a feature for convenience on my longest trips.
If no such thing exists, then I would consider adding in a shunt, but holy crow do some of these seem expensive. The Victron 500A SmartShunt is straight out, since they're $180 in Canada. Next one I see recommended is the Junctek 400A ($85) or 100A ($70) shunts from AliExpress, and finally the AiLi 350A ($70) or 100A ($65). For my use case, where my charger will max out at 70A, and my inverter will max out at 100A (which I use extremely rarely), the AiLi and Junctek 100A are my front-runners.
Q2 - If I go ahead with getting a shunt, is there any good reason to choose one over the other of these options?
Q3 - Is there any strong reason to step up to the 400A/350A version, instead of sticking with the 100A?
Q4 - Are there any top candidates I've missed that are better options?
Q5 - Are there any decent quality "dumb" shunts that would be a very cheap alternative if I just wanted to reliably track usage, instead of one of these smarter shunts that track usage and charging?
Thanks in advance to all you DIYers who have come before me!
