I'm building an battery with 32 EVE LF105 in 2P16S and for the BMS cables I consider solder them to the bus bars, will give more work but I don't like to have a terminal the may interfere in the torque of bus bar screw, I know that some drill an hole in the bus bar and bolt the blm cable there but this will reduce the conductivity in that place.
Do you agree in solder, BMS is JK 150A 2A but it won't have much work cells are A from EVE all with 3,286V.
