I guess the first question is this. Looking at the common port BMS it looks like the load and the charge source are wired to the same bus.
Does that mean that you can charge the cells at the same time you discharge them?? (best guess is only with a BMS otherwise they need to be seperate)
I can kinda think of reasons to keep them separated. Like maybe you want some other device to be able to cut off the BMS and not have it going through the main power.
But if you wire them like the pic, isn't it the same as a common?
Thank you SO MUCH !
Thank you SO MUCH !
