GXMnow
Solar Wizard
- Jul 17, 2020
- 2,702
It is possible that a poorly designed unit might have a problem dealing with a disconnect, but any well made unit should not have a problem. The BMS opening the charge side is really no different from a fuse or breaker opening. If a fuse blowing will cause a device to self destruct, it is a bad design. When the output becomes unloaded, for any reason, the voltage will start to climb up. The regulation circuit should quickly reduce it's output current all the way down to near zero to keep the output voltage at the maximum absorb voltage setting. It should then pull less current from the solar panel, so the panel voltage will rise, but if the system was properly design with the open circuit voltage below the charge controller limits, this should also not be a problem. I did see a few super cheap PWM charge controllers, that limited the battery voltage by actually shorting out the panel with a transistor. This will cause the voltage limiting transistor to try and dissipate the entire power that the solar panels are producing. That may work for a 50 watt panel, but much more than that is a bad situation. Stick with a quality MPPT charge controller, and it should not be an issue.
