GXMnow
Solar Wizard
- Jul 17, 2020
- 2,709
When everything is working correctly, the BMS is just along for the ride. If the cell balance goes out, it will try to pull it back in. IF the cells are well matched, it does not have much to do. A few milliamps for a few hours will keep god batteries in balance. The Charger will stop charging before the batteries get too high, and the inverter will shut down before they get too low, so the voltage protection in the BMS should never be needed.
BUT>>>
There is always a but.. If the cells do drift out of balance for any reason, and the BMS balancing is not able to keep them in range, you could run into a cell going to high during charge or too low during discharge. Depending on how far the inverter or charger is trying to use the pack, an imbalance could be enough for the rouge cell to go far enough out to hit the protection threshold in the BMS, even if the whole pack is still in the safe voltage range. Without monitoring each cell, the charger and inverter do not have any way of knowing if one cell is out of range. The better the batteries are matched, the less the BMS needs to do, but due to how lithium batteries work, a BMS is always needed to make the system safe. Even perfectly matched cells could age differently and become unbalanced as they age.
The question becomes what happens if the BMS has to disconnect. If it does, it means something is wrong. It should never need to happen. So the main thing is we don't want it to damage anything else. Disconnecting the battery from a solar charge controller is not a good thing. Ideally, it should see the voltage jump up and go into constant voltage mode. This would be a good question to ask and should be in the manuals since more and more people are turning to Lithium batteries. If a charge controller can't withstand the battery being pulled due to a BMS cutoff, then I would say that charge controller is not compatible with lithium batteries.
On the discharge side, most inverters will just shut off when the battery is disconnected. It is certainly no worse than a fuse blowing. And that can happen easily from an overload. If an inverter can't survive it, there is a bigger issue.
Unlike a fuse blowing due to an overload, a BMS shut down could have a few different reasons. If a cell keeps going out of balance, it is telling you to repair the battery pack. If it is a current shut off, it is being overloaded, and you need to adjust things to prevent that. And if it is a temperature issue, you need to correct the cause. If it is working correctly, it never should shut off.
Since my system is based on an inverter/charger unit, I had to use a common port BMS. But it is nice to know it can stop charge and still allow discharge, and stop discharge and still allow charge. If a battery is run to low, we certainly want to be able to charge it again.
If a system has separate charge controllers and inverters, then it makes sense to use the separate port design. but common port will still work. It would be interesting to look at the diagrams and see how they layout the mosfets to see if you could easily convert between a split and common port system.
BUT>>>
