sunrise
- Jul 16, 2020
- 206
I am having a bad feeling about this, any advice would be appreciated.
A couple of months ago I purchased 8 105ah (the blue aluminum ones recommended by Will) cells from aliexpress. it arrived a couple of weeks ago. I also purchased 2 JBD BMS with BT modules for the cells. Today I received everything I needed (crimp tools, connectors etc) so I crimped bunch of wires and connected 4 cells to give it a go. After I connect BMS, balance wires and BT module, I installed mobile app and it connected to the BMS and reported 50% charged. I poke around the app and everything seems to be working well. The BT module has LED lit when the app connect to it and once the app closes it goes off. So I just left the cells there.
4 hours later, I opened the app and checked it again, I am surprised by the app showing I only have 9% juice left and that's 40% drop.
I am not sure what is going on here, here are information I can provide so someone with experience can help me diagnose:
1. The battery cells (105ah, blue aluminum shell) is supposed to be new cells. prior to delivery to my house, it was shipped from China and was in transit for over 50 days.
https://www.aliexpress.com/item/4000798882949.html
2. The 120A BMS and BT module:
https://www.aliexpress.com/item/4000425316662.html
3. The BMS mobile app returned 50% charged when I connected BMS, BT module, battery cells, balance leads.
4. 4 hours later when I opened mobile app, only 9% (12.9v) charge left, during the period the BT module was NOT active as the app was closed.
5. I found no component feels hot (BMS, BT module, battery)
6. The battery was not connect to any load.
7. There was a small delta in voltages between cells. min 3.21v, max 3.24v
8. This is the first time I connected the cells in serial.
40ah was a lot energy gone in 4 hours, the fact there was no heat observed makes me concerned that the battery might be defective as it's unlikely that the 24awg wires for BT and balancing could draw this much amps.
I still need to get the a DC source to charge the battery. so for next few days I won't be able to charge it.
Thanks in advance.
Thanks in advance.
