Overkill bms with a piggy back Heltec active balancer. Pack is 48v EVE 304’s. The BMS is reading some cells spiking to 6 volts while the cell next to it drops to .6. Reversed between 3 cells. Reading with a voltmeter showed one cell spiking as high as 3.8 but I adjusted the probe and it dropped back to 3.34. Maybe that was a fluke... All the other cells read normal. I also noticed that it now reads 380 amp/hrs where it used to read 304. Then it would read 0 amp/hrs. I have included a couple screen shots. The only thing that changed on my end was going from using Apple app to Android. I had to shut it all down and thankfully I can go back to line voltage while I get this sorted. Did the BMS take a dump on me? I’m trying to find out how to reset the BMS to factory settings to see if that helps. Kinda freaked me out.
