Ok, here's the deal - precisely because of threads like this. And I ride with LFP (or at least did).
Step 1: Commercially, you pick an LFP starter bat based on a totally fake spec called Pb/Eq. You choose your new lfp battery to match what the oem bike manufacturer called for in lead acid. Forget CCA's and all that.
(If you are diy'ing, then you must use high-rate cells like non-counterfeit Headways, A123's, anything "nanophosphate" and the like) Cells from inside a Miady battery are straight out.
Step 2: The smart ones - if they have the space and budget - will +1 it in size and step to the next size larger - or as large as will fit in the battery bay.
Step 3: Don't leave loads on for hours. These cells are very high-rate, but low in capacity if you look at it from the normal C/20 standpoint.
CHARGER: Don't mess around. Many of these batteries don't have a bms, or if they do, understandably don't do balancing. Yes, the Shorai's have an external balancing port if you want to do that.
So how do you balance these naked batts? With a Tecmate-Optimate Lithium (LFP) charger.
This is the 5A version. They also have a 10A version. Wish they made them even larger!
tecmate.com
Yeah right - how?
@snoobler might dig this:
Tecmate-Optimates don't run a standard CC/CV. Instead of a steady CV, they pulse it. Don't go nuts - I'm not talking about desulphation right now. Just the charge profile. Not fast enough like a true PWM, nor slow like a hysteresis. Put an AM radio next to it, and you can hear the differences. Or watch your voltmeter bounce.
The way that works is that during the rise-time of the pulse, more energy is able to make it into the lagging cells just prior to the unbalanced overall "pack voltage" CV limit is reached where current input is very low - and ineffective at balancing on a series-connected pack-level.
As the leading edge of each pulse more or less "sneaks in" a charge to lagging cells, they balance out. Is it a perfect balance? NO. But it gets you into the ballpark.
The other part of the game is one of DUTY CYCLE protection:
By pulsing, when cells go high, they are not held at that high state of charge long as the leading edge sneaks in a charge.
This actually works for BOTH chemistries such as LFP or AGM. In the case of agm (which I did long before LFP arrived), pulsing the CV when the agm's cells were badly balanced internally, when one cell goes high, it doesn't immediately gas-out! So same kind of reason for LFP (minus any gassing obviously) using the pulsing CV - duty cycle protection.
I'm a HUGE fan of Tecmate-Optimate. But I won't go into all the other stuff they do unless asked. Like temperature checks so as not to charge when it is freezing. There's more, but I'll stop. Their marketing is cute, but I got to talk to engineers years back.
Seems like any mention of a high-priced British designed Optimates goes haywire fast with cheaper alternatives, but this thread caught my attention.
