Hi everyone,
I have recently purchased a 4x3.2v 280ah EVE cells to make my own battery on 12v.
However, I have some doubts about the max load of my BMS. Here's my situation:
I plan on using, sometimes, a 1000w inverter with a peak @ 2200w (183a) for a few seconds
At the same time, I will have an average of 30a connected equipments.
- Normal use would be: 83a (1000w/12v inverter) + 30a (equipments) = 113a -> in this case, a 150a would make a great job, without pushing to the limits
- Peak use would be: 183a (2200w/12v inverter) + 30a (equipments) = 213a -> 150a BMS would not be enough
What should I do? On normal usage, a 150a BMS is more than enough, but will it handle a 20s peak from the inverter?
Thanks in advance for your advices
