I finally got my new sbms0 and installed it. Testing now and I have a question ( 12v 280ah)
Sbms0 is set for hvd at 3.5v ,. Victron default lithium profile set for 14.2v absorbtion. I have one cell that charges a bit faster than the others - I'm not worried much about this, as it only manifests at the very high end of the charge cycle.
What happens is the one cell gets to 3.5v. While the others are around 3.4 (this is at 99% soc). So the pack voltage is around 13.9. sbms0 shuts off the mppt due to hvd on the one cell, so it never goes into float (this is a victron 100/50 smart solar mppt).
My question is:. Would it be better to set absorbtion voltage lower on the mppt so that it goes into float mode and doesn't get get shutoff, or just leave it like it is where it toggles between bulk/off as the battery charges and discharges?
The way this system is currently configured I don't think the mppt would ever go to float even if the cells were perfectly balanced (4x3.5 = 14 vs 14.2 absorbtion value). I'm not that concerned about getting every watt of power from this system, more focused on optimizing life.
Bob
Bob
