Tdcampbe
Hi all. I am running into an issue where my MPPT will stop charging and go into float mode before the BMS says the battery is charged. 100a Daly Smart BMS and Victron 75|15 MPPT. I’m assuming it is a setting issue. I had a cheap BMS on the battery from battery hookup and recently (last weekend) took it out and and top balanced the pack and installed the Daly. Any help would be greatly appreciated as I haven’t changed any parameters on the Daly from factory settings and I know I need to. Thanks!
