NCblueridge
- Jul 31, 2020
- 154
I have an overkill BMS (which I am very happy with), it comes with 10 AWG wires by default though. I can connect directly to the positive side of the battery, but the negative side on the BMS is that size wire. I assume that limits me to around 30 amps max given the Amp rating and wire sizes. This is ok on that battery build since it would only pull 30a max on occasion anyway, but I am doing a larger build and would like to size accordingly since that one will have an inverter. One the 2nd BMS ordered, I added the 8 AWG option.
Anyway and sorry if this is a stupid question, but I assume I am still limited to amp restrictions at 10 or even 8 on the BMS with a 12 volt system with an inverter on the larger system?
