BMS negative wires and AWG/gauge question
I paid a writer/programmer to create the entire manual from scratch
Well props to you and to him/her, great work, you might be the first seller that provides actual high quality documentation and support for an affordable FET based BMS. You are adding good value to the products you sell, and I hope (and think) it will pay off.
I can also attest that the low temperature sensor works on the BMS, I tested that the first day I had mine hooked up and also compared it’s temp reading with my very accurate Thermoworks probe, It was within one degree.
overkillsolar has the good stuff,ships quickly.packed well.love all his products.
i have 4 24 volt packs in parallel.funny thing is,they equalize each other.i do not top balance,i build and connect to existing banks and off i go.works with out a hitch.
