Hey guys,
I have a 16s 3p 10kw liion pack with no current bms.
I'm looking for a good inexpensive solution to balance and monitor all cells individually. The pack is 66vdc max as 16s or 8s 6p at 33vdc. I want to be able to monitor it. Bluetooth would be ideal. Currently looking at the 16s smart bt 30amp bms for $120-$150 each. The other option would be some smaller 8s or 16s non smart bms for like $20 each and then some type of 48 cell display. What other option can you guys think of? By the way the pack it run at less than 0.5c and stays well balanced within 20mv using those cheap $10 8s balancers (currently set at 8s 6p. Or 24v (33vdc max) system..
Thx
Thx
