I have an older model Inverter from Spartan. The model is 6600/24 which is capable of split phase output. Although I've had it for several years, I've only recently put it into service and begun to play with it. I'd like to ultimately put 3 24v batteries 280ah Eve cells each with a 100a overkill BMS in parallel. My question is in regard to the BMS. Will the maximum draw still be limited by the 100a across all 3 batteries, or will the draw spread equally across the batteries so that a potential 100+ amp draw would be within the capacity of the overall battery bank?
