ElectricDanimal
- Sep 21, 2020
- 34
I have a 48v inverter, charger, (mpp LV5048) but i have to use separate solar charge controllers at 24v. I will link 2 -24v LifePo4 batteries in series. (I have a maximum of 60vdc from my panels and they can not be used in series)
1. can i use 1-48v bms even tho the solar chargers are at 24v?
2a. is there any advantage to using 2- 24v bms on each battery ?
2b. what happens when the inverter charger tries to charge at 48v using the on board charger if the bms are 24v each?
3. can anyone help or recommend which bms to use? (i would like bluetooth compatible)
I am new at this and would appreciate any help.
