xTratrestrial
- Mar 13, 2021
- 16
Long awaited, 50x CATL 280ah will be hitting my door within the next month. I still need to make a BMS order and am hoping to get some good suggestions on the best way to manage these in 16s3p. I have several questions that I'm still unsure of after digging through quite a few threads.
I've pretty much landed on using 3x Overkill 16s 100a for each of the series groups. One of the primary things I'm still unsure of is the importance of individual parallel group balancing. Should I be using a 4th BMS for this, or perhaps a balancer, or do I not need to worry too much about it? I'm aware that voltage indifferences should balance themselves across parallel groups since a lagging pack would offer less resistance, but what about longevity? What if one pack, at some point, for whatever reason, degrades faster and there becomes a slight capacity mismatch? I would think this could be noticed easier and managed better if there were another BMS/balancer on the 3p groups.
Another thing I'm trying to consider is future growth. If I were to add to the bank later on, if I wanted add used cells/different chemistry or simply add on a 4th parallel group with 150ah cells instead of 280, can this be done without negative repercussion if there is a BMS/balancer managing the parallel groups?
Finally, if anyone has suggestions to toss in regarding compression, I'd love hear opinions here as well. I haven't began to dig into that topic yet, but I do know that some folks are using boxes or other structures while others are simply using Kapton tape on these cells. Reading shows that CATL typically have thinner walls than other manufacturers, so I feel like leaning to the side of some sort of tight fitting box my be prudent, but I'd really like to hear from others with experience.
