Ljbezuidenhout
- Jul 28, 2020
- 7
Hi. I have just built a 120Ah LifePo4 battery using 4 cells with a BMS, which is all fitted into a battery box to be used for camping. I don't want to have to open up the battery box each time I want to disconnect the BMS when putting it into storage or unplug and plug in the balance leads too often. Is it possible to put a switch onto one of the balance leads and mount this switch on the outside of the battery box, to be able to "disconnect" the BMS via the switch? If it can be done, which balance lead cable would the switch need to be installed on? Thanks
