I have no experience with bms's and none with Li batteries, so this is new to me. After getting my new system hooked up I have a few questions ?
Initial batt charge was done with modified 10 amp charger (purchased with batt), when charging was done the meter was at 58.4 v. When I turned the charger off the meter changed to 56. At the time, I thought nothing of it but now I'm wondering if that 56v should be my float voltage?
I set the growatt float to 54 because it is what the battery guy said to do and I watched its first cycle yesterday. I used 2 led lights that kilowatt says pull 326 watts each (so totally balanced load) and the growatt said it was doin 661 watts. I ran this for 8 hours and then switched the AC in on, I set the growatt to a 10 amp charge and a few hours in I raised it to 20a, at 10 the fans come on bout every 10~15 min and runs for 2~5 min, at 20 the fans run continuously (nothing to do with my ?, just adding info on the 6000T for others).
As the batt got to 54v I expected to see the charge amps reduce (float) I admit I have no clue what float does which is why I was watching and nothing, just kept charging. But when it got to 56v the charge current dropped to .1a and I am assuming that .1a is float ?
Note: there is no communication between the batt and the growatt.
So does the bms override the inverter ? Or what am I missing? And finally should I change float to 56v ?
Thanks !
Thanks !
