I was wondering if anyone can tell me why it is okay for the wire connection to the negative terminal of a battery from a BMS to be significantly lighter than the gauge of the wire connected to a battery’s positive terminal?
For example, the Overkill Solar BMS documentation recommends 2 or 4 AWD for the positive but only requires dual 8 or 10 AWD to connect the BMS to the negative terminal
Thanks, Eric.
Thanks, Eric.
