But here are some of my questions about this BMS if anyone could answer I would be appreciated:
1- In the user manual is mentioned that using these BMSs in series or parallel are not allowed? Why ? because there is 900V, 500A contactor ! it is not mosfet based bms that limit you on drain sorce voltage limitation! or sharing equal current of multiple parallel mosfets for parallel connection!
I want to know if someone use it to series up to 4 x 48V , 100A pack still is not allowed to series these packs?
Ok I used this BMS parallel, 2 times a 10kWh NMC block. I didn't like it.
It might look like parallel is better with the relays but now I think it is actually worse. Because a purely MOSFET BMS is contentiously busing with monitoring and possibly limiting current. When the relay is open, it just goes.
Which is fine if they open and close at the same time. The design was as such that the corner cases (low and high voltage thresholds as well as temperature) would rarely occur.
However in real life they were not that in sync. That may have had to do with start up scenarios (inrush current to an inverter)
Anyhow, I witnessed way too much out of sync behavior resulting in balancing currents between the two 10kWh, to often.
I switched to a CAN bus system, monitoring all cells and just have one central activator for opening/closing the relays.
This was more expensive of course, but I will never waste time again trying to parallel with these kind of relay based BMS.
Every occurence of Chinese BMSs being used parallel are always mosfets I think, typically in solutions that are meant to be paralleled. (like server rack batteries etc)
So it is defenitely possible. However, not with this BMS and I have found that the cheap price is causing me to burn more hours into it. So from now on, I will only use higher grade CAN bus BMS for paralleling NMC.
