Hi, I’m so happy I found this forum. I didn’t know how much I didn’t know.
I plan on powering a small boat with a 35A / 24v fixed pod motor using 8, 280ah LifePO4s.
The cells have to be in 2 seperate packs (4s 12v)
Should I put a 4s BMS in each pack or use one 8s BMS which will require lengthening the sensor cables and installing plugs/sockets.
I’ve seen here, that there be issues using two 4s 12v packs in series?
Are some BMSs more suitable for series connections that others?
Thanks, Mack in Brisbane Aus
