groundedchevy
I recently moved my boat to a dock without power, and I would like to use a solar panel connected to an EVPEVER dual battery charge controller to keep my three batteries charged (starter battery (12v) and 2 12v trolling motor batteries (24v)).
I planned to mount a solar panel on the roof of the dock. What is the best way to quickly connect and disconnect the solar panel from the boat when I use the boat? In my head, I would have an on/off switch or breaker mounted to the dock with a plug below it.
I also have a DC charger that will use the outboard alternator to charge the trolling motor batteries in addition to the starter battery. I thought this would help if I fished multiple cloudy days. I haven’t researched panels yet and would love a recommendation for my application.
Eventually, I plan to add an inverter to run my boat lift (currently using my F150 inverter and an extension cord). It peaks on startup around 2000 watts and runs at 1500 watts for less than 4 minutes. Is there a budget inverter that anyone would recommend for this application? The smaller, the better due to mounting space.
Any other suggestions or ideas would be appreciated.
Charge controller link:
EVPEVER 20A Solar Charge Controller 12V/24V Auto Working Dual Battery Solar Panel Charge Controller PWM 20AMP Intelligent Solar Panel Batteries Regulator for Motorhome, Caravan, Boat
