Hello,
I am installing a totally separate (isolated) solar power system in my RV that will not connect to the existing power system. For this year, I want it only to run a mini-split. I do not want to mess with the existing RV breaker panel for now. I have a separate Square-D Homeline breaker panel to take AC output from my Growatt inverter.
1. Do I bond the neutral and ground wires in this panel since it is not a sub-panel? Or do I have them on separate unconnected bus bars in the panel?
2. Where do I attached the ground to? The vehicle frame of the RV?
Thanks!
Thanks!
