Joe BoyKey
Watts, Watts, more Watts
Here it is, start off with the grand design Word generated schematic/layout, pretty simple after 1 year of sitting at home and trolling EVERYWHERE, basically 2 systems - 12v revamped Agm 10 year old system (new used agm batteries and Make Sky Blue CC) tied to a 1 year old Lifpo4 system, via a new Victron buck converter and low voltage detect board that turns on at 12.3v until the sun comes up, rare but does happen on cloudy days. Multiple strings of Panels are separated to to 2 charge Controllers (48v) 2nd controller can be dumped into a newly added 30 gallon hot water pre-heater, took a year to get here, just finished 48v 302ah Diy Catl build to get to 51.2v @ 1002 ah - 51.302kwh, Once obtained Solar Assistant to monitor Growatt SPF-6000T-DVM I found Home Assistant - WoW, Joe.
Old 12v sla - new 12 agm with 200ah Lifepo4 backup
New 1 year old Growatt - MakeSkyBlue bad-as system
10 year old 12v panel array minu 2 Sharp 167w panels
Back roof winter shaded panels
51.2v 1002ah Batteries - started out a year ago with these 51.2v 200ah, was too small for Growatt
Added 3 Gyll and 1 Gyll EG4 batteries, then built Diy - 64 - topband/Navitas 4p16s, and just finished 51.2v 302ah Catl Diy battery.
Solar Assistant
Home Assistant - monitors Solar Assistant, Ambient Weather Station, Emporia Vue circuit monitor and Windy.com widget, love this stuff.
Solar Assistant
