Skinny76
- Jan 17, 2020
- 83
So, I bought the BougeRV battery that Will reviewed where the BMS wasn't plugged in all the way. It has performed well running a 12v fan and using an inverter to power a CPAP on a few occasions. It has been about a month now. I have not tested capacity.
I connected a Victron Smartshunt to monitor it. I do have an issue though. It has never cut off while in use, but the BMS must be kicking out every now and then since I can be at 65% (just for example) and without a charge, the Victron shows an instant jump back to 100%. It has done this three times in a month. I assume it is the BMS of the battery.
I don't have anymore info the that, but just wanted to put it out there. Could it be the shunt? I have everything torqued down well.
Thoughts?
Thoughts?
