I ordered one of these to try out as a replacement for the emporia vue 2's I use now.
Its basically the same hardware but supports you using your own server for the data. Will run 100% offline with full privacy. Feeds data to any mqtt server you setup like what I have for home assistant now.
$128.99
I'll post how it does when it gets here but I think it will be my new go to since its 1/2 the price and no internet required. Sucked not getting data when the net went down which it does if the power goes out so no monitoring stuff that is running off the inverters during that time.
$128.99
