Have now installed a battery to battrey charger 40a. So now have 3 x 280ah lifepo4 batteries in paralell. Which I use with the bow thruster and anchor winch pulling 170a on the thruster. I have 3 x 110 ah starter batteries slight over kill but possible back up. Having used the sterling alt to batt charger for over a year on lithium setting with no problem am going to see which works better. I have only ever run the batteries down to 50%. My alternater is a 100amp never over heats, but I do have an alt saver attached just in case a fuse blows but I have never seen an issue.
Next move may be to use an additional lifepo4 as a starter battery but how will I charge it ??? What dammage will occour ?
Pulling high amps from a lifepo4 for a matter of seconds will this degrade the battery and to what extent.
My engine is a 55HP Nanni diesel.
