timselectric
- Feb 5, 2022
- 18,453
You done all the hard work. Agreeing was the easy part.Thanks. It took me a while to chew thru the red herrings to figure this out. Glad you agree.
Ok thanks.The reason you see the drop-off from 25.5v to 23.3v with only a 0.5a load is lifepo4 ah drop off a cliff after 3-3.1v that's why EVE like most other manufacturers state a soc of 10-90%, meaning 280ah cells are really 220ah and as you only charged them to 80% you have lost 10% more.
Did you not do a capacity test on each cell before building the bank?
I would do a full charge to 3.65v 29v and don't go as low, most people I know use around 190-200ah from the 280ah cells.
I would not. I am not sure i've heard of anybody doing this, especially without knowing the real, measured capacity.Should I adjust my ah pack size in my jk and victron to 195ah pack down from 280 to get better % readings?
I have about 100 cells in about a dozen different batteries and have never done a capacity test.I did not do a capacity test. I am new and no one told me to do that.
Ha...... At the 4-6min mark this guy proves what you said about low and slow! The lower the ah charge the higher the pack ah capacity.I am not disagreeing with anything Hardergamer1 wrote. I'm not even against hitting the battery with one big "full charge to 3.65v 29v" charge once you get your current issues understood (i am too conservative and not inclined/desperate enough to try this on MY cells, yet).
I think you should give your new full charge parameters a go and see where you end up. Change one thing at a time, evaluate and adjust.
His conclusion (and mine too), is not that the "pack Ah capacity" changes at different charge levels.Ha...... At the 4-6min mark this guy proves what you said about low and slow! The lower the ah charge the higher the pack ah capacity.
Im sold!His conclusion (and mine too), is not that the "pack Ah capacity" changes at different charge levels.
His point is that with a lower A (amp not amp hour) charge rate, the cells will absorb more during the bulk stage (and need a shorter absorb stage). ** the slower you pour a beer (presumably less foam), the less time you need for foam to settle and top off the glass **
Conversely, charging faster, the cells absorb less during bulk stage (and need a longer absorb stage). ** the faster you pour a beer (presumably more foam), the more time you need for the foam to settle and top off the glass.
Where this applies to your situation that you came here with, is that you did not have ANY absorb stage and a high charge rate did not allow for complete cell charging (lots of foam!). The capacity of the glass did not change, just the amount of beer you put in the glass.
Yes, i do not rely on absorb because i charge pretty slow and conservatively.In your advised settings I noticed the bulk and absorb voltages were the same. How does that work then? Isnt it the same with a different charge name?
Well the issue I will have with this is that Im charging with a very expensive honda generator and burning a lot of gas and putting a ton of hours on the machine. Both cost $$$$$$Yes, i do not rely on absorb because i charge pretty slow and conservatively.
The down and dirty about the bulk vs absorb is that in the bulk stage, the charger strives for constant current (up to bulk voltage as fast as it can).
So during bulk, the tap is wide open pouring as fast as it can, until the top of the glass is reached.
During absorb, the tap pours slowly so that the glass does not overflow yet remains at the top.
The absorb pour continues for your absorb time or until the pour reduces to your absorb tail current (glass is so full and so little foam you can only put in a few drops at a time).
Mine settle to 3.35Vpc with no load which is same as yours.Graph shows 3.34cell volts at 87% soc.
OK well.........Mine settle to 3.35Vpc with no load which is same as yours.
Wherever possible, i set 3.35Vpc as my 100% Soc. The voltage above this is surface charge and represents negligible capacity. I think it makes Soc readings more accurate.
Sounds like you are learning a lot about your cells and charging. Well done!
I suspect that if you wanted to minimize generator runtime, you could charge at a high amperage until your top charge voltage (3.45Vpc? or experiment a little higher, maybe 3.5Vpc). Then implement an absorb phase of 10A at 3.45Vpc for 15-20 minutes. You will probably discover quickly what works best for YOUR cells.
Yes, at least use max amps while using your generator for bulk.I would only use the generator for bulk (fast) charging.
Also while we are talking is there any way to not have to sit and watch the grass grow while charging?
I am 65 miles from Canada in the PNW. We get sun only when the Gods think we need it which is 20 mins every 4 days. More panels wont help when solar amps are zero. I went 60 days once and not a drop of solar charge. Rained the whole time! Im also down in a valley so no wind and I dont have a stream so no micro-hydro. The greedy power company wants 24,000 to run a line down my driveway and I refuse to pay the extortion fee + monthly protection money.Or pick up more panels, skip the generator all together.
