Stormthirst
I'm finally getting to set up my solar panels ( 4x 425w panels, 48v each) and I wanted to put a breaker in between them and my EG4 3000w inverter. The inverter came with a DC breaker and I was hoping to use that. The breaker has two ports, one labeled "Line" and the other "Load". Which side should be attached to the panels and which side should be attached to the inverter?
Is this breaker going to do what I want it to do?
