I'm planning a simple system and would like advice/suggestions on breakers vs. fuses/switches:
The system:
- Single 100w poly panel
- 20a PWM SCC
- One 12v SLA 100 amp hr. battery
- 10agw wire
- Loads are LED lights and DC fans.
The problem:
I like the idea of in-line breakers so I can also easily switch off a component (like PV in to SCC) but having trouble finding ones with decent reviews. So far these look like the only/best options:
ZOOKOTO 20A Circuit Breaker Fuse Inverter with Manual Reset Button
T Tocas 32v DC Circuit Breaker Fuse Inverter with Manual Reset Button Switch Fuses 12V 20A
Questions:
- What fuses/breakers you are using and how you like them?
- Is it more practical and less hassle to use an in-line fuse and wire in a switch for manually cutting off instead of these breakers?
The system:
- 20a PWM SCC
- 10agw wire
The problem:
Questions:
