SveinHa
I can select a few baud rates but immediately when hitting the flash button, it reverts to 19200. My inverter is so dead that I get no response whatsoever when trying to flash.You have tried to switch Baud Rate?
I have a couple of links but with the danger of bricking the inverter, I guess it is not wise to publish them...however havent found a place to download,
i was hoping for an official voltronics download locationI have a couple of links but with the danger of bricking the inverter, I guess it is not wise to publish them...
Thats what I have... the URL start with http://ftps.voltronic.com.tw/ but the rest contains mainly of a long string with random characters so it looks like a special upload for me. The first link I got from EASun had a different content the first time compared to later visits...i was hoping for an official voltronics download location
No update for me, 6 days since last sign of life at EASun support...View attachment 106435
That is the last update......
Hope they assist you finally.When reporting thru PayPal, EASun support finally came to life and urged me to NOT to escalate my case. I'll give them a couple more days but they have already wasted too much time ignoring me...
I received a new firmware today but it is too late since I'm unable to communicate with the inverter...
U1 fw: 90.10Which firmware numbers they sent you ?
90.06 is newerU1 fw: 90.10
Hello , did you flash your units. Is 90.06 solving the export to grid problem ?90.06 is newer
have a different unit ( 8000 max), running 90.06Hello , did you flash your units. Is 90.06 solving the export to grid problem ?
Do you notice the 8000max feeding back to greed in SUB mode when the PV production exceeds house consumption (and when you switch off a large consumer) with the 90.06 firmware ?have a different unit ( 8000 max), running 90.06
i have uploaded the firmware for my inverterserie, display,and flashtool + manual in the resources section here.
not sure if it works for you, use at own risk and responsibility
no sirDo you notice the 8000max feeding back to greed in SUB mode when the PV production exceeds house consumption (and when you switch off a large consumer) with the 90.06 firmware ?
Googletranslated:Vi har gjennomgått transaksjonene dine og har avgjort å avvise kravene. Vi forstår det slik at varen som er knyttet til denne saken, ble endret mens den var i din besittelse. Derfor kan vi ikke avgjøre om varen er vesentlig forskjellig fra den opprinnelige beskrivelsen, så vi kan ikke avgjøre kravet i din favør.
I only followed orders from EASunpower as documented in the attached email...We have reviewed your transactions and have decided to deny the claims. We understand that the item related to this case was altered while in your possession. Therefore, we cannot determine whether the item is significantly different from the original description, so we cannot determine the claim in your favorite.
