Thought about using trunking to run the busbar in but decided the silicone booties over the busbar lugs and shrink tube over the busbar should suffice. Used small zipties to route the balance cables and made a top for the battery box out of plywood, to cover it all up.
I think I have a plan for this today … going to cover all with vinyl panel for protection and put wood top on entire box, mounting display screen toward front to have complete visibility of status and maintain access without disconnecting everything,Thought about using trunking to run the busbar in but decided the silicone booties over the busbar lugs and shrink tube over the busbar should suffice. Used small zipties to route the balance cables and made a top for the battery box out of plywood, to cover it all up.
Yes, I will keep them unwrapped, I have seen little to no heat at all for the rates I push and pull so should not be a problem.Unless the bus bars are very oversized and won't get hot it would be better to mount them where they get convection cooling. This also means no heatshrink, instead plexiglass shields to allow airflow. Or mount in a channel to do it.
Some people seem to put the temperature sensors between carefully chosen cells, but then you have to be careful to electrically insulate them from the cells on all sides.Now new question .. how and where does everyone attach the temperature censors? How and where .. suggestions?
Yes it would appear I have three.. one build into the MOS Of the BMS and the other two I can place..Some people seem to put the temperature sensors between carefully chosen cells, but then you have to be careful to electrically insulate them from the cells on all sides.
A previous discussion in this forum seemed to indicate that the cell terminals were pretty well thermally connected to the internal cell temperatures, so putting temperature sensors with lugs on top of carefully selected bus bars also makes sense.
Does the BMS have a temperature sensor to measure its own (heatsink) temperature? If not, you might want to put one there.
I have a temperature gauge int he bay just above the battery for room temperature … so I guess they can go on two parts of the pack cells…I place one on the outside of an outside cell to give me an idea of room temp and what the outer cells might be, then one near the middle of the pack for the same reason.
Oh this is a good way to do it, gives a nice safety layer to ensure we have the cell temperature..My leads I just grab some leftover packing foam and lay the probe on top nested in the groove between 2 cells. Some hot glue around a chunk of packing foam on top keeps it reading the cell temp more accurately than the air temp around it.
Thanks. I've got a nice new pair of strippers that do a great job with the ~22 AWG wire, nice crimper and quality crimps so that part is is going relatively smoothly.Not an issue at all, we do it all the time. Pro tip though, most BMS leads are really thin and have a hard time getting a good crimp into ring terminals. Strip off about double the insulation you need and fold the wire over so the crimp has more meat to grab on to.
I have a pair of crimpers with maybe 16different sets of dies that make a longer crimp and folds it in much better than the standard pair of cheap crimpers. Before those, the ring terminals got soldered.Thanks. I've got a nice new pair of strippers that do a great job with the ~22 AWG wire, nice crimper and quality crimps so that part is is going relatively smoothly.
I am building 2 x 12.8 314ah batteries - I've choosen 3mm poron for between the cells and a 300amp 4s JBD BMS..
Minimum 3/8" thick 6061 aluminum. Buy the 8" wide bar stock if you have a way to cut it.I am still working out if I want to use aluminum or steel plate or wood at the ends.
Good choice on using Poron.
Why did you do that.. anyone get these questions …View attachment 275146
They hold everything together and they can be purchased at Home Depot very cheep .. some used to use them for compression, I did not do any compression they are more their to hold pack right where I placed in and no movement.Why do you leave the all thread long? I notice that with a lot of builds...long threaded rod
I use a Harbor Freight composite handle 1/4" drive ratchet. Tape on the 10 mm socket, a cheapie works so you don't have to remove the wrap. The head of the ratchet is still metal but if dropped on a battery terminal, there isn't enough length of the metal to reach another terminal. Has a push button so socket won't come off.Why did you do that.. anyone get these questions …View attachment 275146
It looks good, just leave them long enough so it is easy to put the nut on if you ever have to disassemble.EDIT: just reread.. I will not leave them I will trim them for sure..just have not finished yet. But whated a picture of all 6 so @Zwy would notice that I did have enough room for all 6 …
