Can you guys recommend changes to my build list before I order anything?
I had a Bluetti AC200Max that let the smoke out and I need to use the panels I have installed.
This setup is just ment to run freezers and recharge electronics when the power is out.
Roughly 2.1kw/day.
Already have the panels.
URECO solar panel specs:
Model - D7K390H8A
Pmax - 390w
VOC - 48.53v
ISC - 10.16a
Vmpp - 40.39v
Impp - 9.66a
Things to order.
Does it make sense to go with a 48v system for efficiency?
Any help is appreciated.
Thank you!
Roughly 2.1kw/day.
Model - D7K390H8A
Pmax - 390w
VOC - 48.53v
ISC - 10.16a
Vmpp - 40.39v
Impp - 9.66a
Things to order.
- 24V 200AH 5.12kWh LiFePower4 Battery by EG4
- 3kW Stackable 24V 150VDC 80A Off-Grid Inverter by Growatt
- 250V 63A Low-voltage DC Miniature Circuit Breaker for disconnecting the solar panels.
- 2 AWG wire for Battery connection.
Thank you!
