BigTexasFlex
- Sep 12, 2020
- 1
I need some help as I am endeavoring to build my first battery bank.
Namely, I am aiming to build a UPS for 2 hail covers that inflate to cover my cars. Sometimes, the hail storm can knock the power out for a few hours.
At this point, I don't see any solar aspect for this system. Just charging from the wall plug.
Each hail cover use 12 volt DC, 5 amp power supply.
I used a multimeter to determine they use about 3.4 amps each when they are running.
I am likely to buy the Fortune LiFePO4 3.2v 60AH 10C cells. I could put 4 in series to get 12.8 volts which could power these hail covers in a power outage. I like the Daly BMS 4s 12v 15 amp.
My goal is to be able to charge this pack with both hail covers running, drawing about 7 amps. Specifically, if the power to my home fails due to a storm, I want the hail covers to continue to run until the low voltage cutoff disconnects the load.
What size charger do I need to achieve this? And can I do this using the Daly BMS 12v 15 amp?
My very uninformed guess based on the schematic for the BMS is that I would need a 12v DC, probably something like 20 amp power supply to plug into the wall? That would give me head room for the hail covers to run totaling 7 amps and also the 8 amps the BMS draws to charge the bank?
If I've left out critical information, let me know. I'm very new to the DIY battery bank game.
