We have an off grid vacation place. No grid power. I use Schneider Conext equipment with a 5,500 watt inverter and a 60a solar charge controller. Been using lead acid for six years but time to get new batteries. I'm going to order 16 of the prismatic 280ah cells from Deligreen. I've been reading until my head spins about BMS. Though I was sold on the Orion BMS Junior but it doesn't appear to be able to limit current or charging without hooking relay outputs to my charger and inverter. This seems overly complicated and not sure it's even possible on my equipment. The specs of my equipment is listed below. I need a BMS that has over-discharge disconnect, temperature disconnect and over-charge disconnect.
My solar charge controller is 60 amps and I have the ability to customize all voltage settings of bulk, absorb, and float. I can set the amount of time in absorb and I can limit the charge percentage.
I would like to have digital screen for the BMS or Bluetooth. Remote wireless monitoring would be great. But these are not must have options. I can monitor my solar equipment remotely so I can see the state of charge assuming I am able to use my Conext shunt based battery monitor with LifeP04s.
My specs:
Inverter: 5,500 watts continuous output; 9,500 watt surge for 1 minute; 9,000 watt surge for 5 minutes; 7,000 surge for 7 minutes
26 watts idle consumption; 150 amp DC charger that can be set from 1% to 100%
I don't mind spending some money on a quality BMS. Our place will be vacant for several months at a time so I need a quality and reliable BMS.
Thanks.
My specs:
Thanks.
