pzado
Hello,
I watched this video from Lithium Solar and ended up building one of my own. The following is my equipment:
EG4 3kW Off-Grid Inverter | 3000EHV-48 | 3000W Output | 5000W PV Input | 500 VOC Input
Trophy Battery 48V100E-2UL
2 x Bifacial 200 Watt Solar Panel 12V 10BB Monocrystalline Solar Panels High Efficiency Solar Module
2 x 200 Watt 12V Monocrystalline Solar Panel High Efficiency Module
I have ran the above configuration in both parallel and series. Due to being a DIY beginner my worry is that I am not sure if I am using the panels as they say they are 12V. Do I need to buy 48v panels?
Back to my issue. So I have come across in the Hand Truck Power Station video below is at the 12 minute mark you can see that he connects the positive to the negative terminal of the inverter and the negative to the positive. I have watched another YouTuber (Will) build a similar truck and while he doesn't specifically address this it seems from his video the positive is on the positive and negative is on the negative. Same for any other videos I try to find. When I connect my setup like Lithium Solar did I don't get any power from Solar Panels and worry I may have damaged my inverter. Any thoughts would be greatly appreciated.
The video is linked here: Hand Truck Power Station
