EvergladesRoamer
Hey everyone — I just bought a retired ambulance on a 6.7L Cummins diesel and I’m converting it to full-time vanlife. I want a 48-volt house system that can run a ductless mini-split, an induction cooktop, Starlink, hot water heater, lights, TV, and other typical loads — and I’d like the battery bank to last a couple days without charging. I can weld and will build the battery enclosure (leaning aluminum for weight).
What I’m hoping to get from this thread: real-world sizing advice, recommendations on Victron (or equivalent) components, tips on alternator upgrades / DC-DC charging, and any gotchas (BMS, ventilation, wiring, soft-start for the mini-split, generator/shore integration).
What I have / constraints
Appreciate any advice and links to model numbers or wiring diagrams — thanks!
I’m glad I found this community
- Vehicle: retired ambulance with 6.7L Cummins diesel (running and mobile).
- Prefer 48V house system (weight/efficiency reasons).
- Goal: battery bank to comfortably run critical loads for ~2 days off-grid.
- Loads I’ll run (typical): mini-split A/C, induction cooktop (intermittent), Starlink, hot water heater (TBD: electric vs propane), TV, lights, water pump, fridge, and electronics.
- Prefer Victron ecosystem (inverter/charger, DC-DC, Cerbo GX, BMS) but open to alternatives.
- Is 48V the right call for a rig this size vs 24V? (I’m leaning 48V for lower current / smaller busbars.)
- Recommended battery capacity and maybe best bang for buck in which batteries to look into (kWh / Ah at 48V) for 2 days for the loads above?
- Inverter sizing — MultiPlus II 48/5000 enough, or should I go larger to cover induction + A/C start loads?
- Best approach to charge from the vehicle alternator (DC-DC vs direct)? Alternator upgrades you’ve used on a 6.7 Cummins?
- Recommended Victron models and any alternative parts (BMS, contactors, shunt, Cerbo GX, remote panels).
- Real world tips: soft-start device for mini-split, wiring gauge, fusing, ventilation for battery box, achieving Shore+Alternator+Solar seamlessly.
- If you’ve done a similar ambulance → vanlife conversion, please post photos and wiring diagrams.
