I HAVE:
PANELS:
18 250 WATT PV PANELS 37.6 V SS250P-60
Open Circuit Voltage 37.6V
Voltage at Pmax30.3
Short Circuit Current (A) 8.85
Maximum system voltage 600
Fuse rating 15A
BATTERIES:
CELLS 400 SPIM08HP 4.2 V
Nominal voltage 3.7
Maximum charge 120A
Continuous discharge 200A
Pulse discharge 400A
Cut off 2.5V
MAGNUM 4448PAE 120-240 V 4400 Watt inverter charger
ME ARTR ADVANCED REMOTE PANEL
Midnite classic 150 one on motor-home and one on trailer
I need smart bms with Bluetooth to IPHONE
I hope to do 12v batteries 4s12v in series for 48v i am leaning towards 4 packs of 10 cells in 4s12v per battery and series 4 batteries together of 80AH = 320 AH ON TRAILER SYSTEM
I will install 15-18 250 watt solar panels ON A 27' trailer with slide out mechanism.
on the motor-home I have 660 watts of solar with a Midnite classic 150
I plan on using 320 cells for 48v trailer system and 160-320 cells on the motor-home separate Systems
I appreciate any input to choose the best option available.
There are battery shunts, combiner boxes solar surge protectors and other parts that are not listed
PANELS:
Voltage at Pmax30.3
Fuse rating 15A
BATTERIES:
Nominal voltage 3.7
Maximum charge 120A
Cut off 2.5V
