Am buying parts and pieces for a new pop-up camper, but want to use in the present camper (which currently has no solar). I plan on buying a 100 W briefcase panel, 20' cables, a Victron 10/30 MPPT and a Blue Sea fuseblock. The present AGM battery is just charged off the truck. Will run the cables into the camper through the turnbuckle access, into the Victron and have the fuse block wired to the AGM battery (with a fuse on the positive terminal). Is there any other parts/pieces I should be looking at? The current battery has a simple Bluetooth battery monitor on it already. Thanks for any input.
