Bobfa
A little backstory first:
I have several dead Lead Acid batteries from UPS in my garage and a couple of large ones from—sump Pump Backups. Like Akline batteries, I am tired of early failures and other issues around older technologies. I also have a 5.5KW gasoline generator that I can hook up to circuits in the house as needed. I removed a Manual transfer switch from service while planning this project.
I have several goals in mind.
1. Emergency sump pump power.
2. UPS for networking, computers, security, and refrigeration.
3. Emergency lighting, garage door, furnace.
4. Grid Charging
5. Possible/Probable PV installation for partial supply
6. Location is in Chicago Suburbs
7. The system is 240v split phase, but I have no critical loads that need it.
I call this a scalable whole-house UPS with an optional solar supply. We have worked for several years to reduce standby loads and eliminate heavy peak loads. I have a good handle on the total load.
Initial thoughts on system design.
I am considering using Victron equipment for control and looking at 48-volt battery systems to reduce current needs. The first thing I HAVE to power up are the sump pump 1/2 hp and the network+nas.
Bob
4. Grid Charging
Bob
