Factory400
- Jul 15, 2020
- 387
I have been considering my options for an off-grid mobile power system for a while. On the topic of the battery storage, I recently decided on 24v LifePO4.
Requirements -
Basic use: 100Ah
Typical use: 200Ah
Typical use with hopeful rainy day energy budget: 400Ah
Max load 2.5kW
Average load 750w
Initial thought was to build the pack with large prismatic cells to get 200Ah. This is the lowest cost and easiest implementation, but I was concerned that if a cell (or BMS) goes bad - the whole pack is dead.
If I build 2 parallel packs with 100Ah cells and one goes bad - I would still have half the capacity to muddle through the days. As need increase, I could just add matching 100Ah packs for additional capacity and redundancy.
The question is this: Am I over-thinking this? In the context of reliability (not being in a zero-power situation in the middle of nowhere) is going with multiple parallel packs going to improve the reliability compared to a single large pack? My thinking is that if push comes to shove - I could re-arrange cells in the field to repair packs.
Most likely, I will be getting cells from the usual vendors on Alibaba (of which I am not very trusting). The BMS system will be rather high-end and wholly of partially designed/built by me. I am an electrical engineer that specializes in power electronics. I do not, however, have any practical experience with battery packs. Lots to learn.
Requirements -
Basic use: 100Ah
Typical use: 200Ah
Max load 2.5kW
Average load 750w
